71 911 leaking bright blue fluid...?
Hi all,
I recently noticed a small puddle of very blue fluid collecting underneath the old 911 - pretty much right at the center of the car.
The color is kind of throwing me off, since I'm not sure what it could be. Usually if I saw blue fluid I'd think it was antifreeze...
Is it transmission fluid?
Or is there such a thing as blue brake fluid? I haven't bled the brakes since I've owned the car.
Any suggestions would be helpful...
thanks!
'71 911E
Golden Gate Region PCA
Old 04-10-2005, 05:01 PM
MovOvr1's Avatar
There is such a thing as blue brake fluid, easy to check. Is it windshield washer fluid?
b
Brian
BLK 79-930
Old 04-10-2005, 05:03 PM
smstcoach's Avatar
Send a message via AIM to smstcoach Send a message via Yahoo to smstcoach
I would bet superblue brake fluid. I would not drive the car until figured out.
Old 04-10-2005, 05:05 PM
HarryD's Avatar
Swepco 201 tranny fluid is blue as is ATE Blue brake fluid.
where excatly is the puddle? Is is near the nose of the tranny? Lift the plate betwen the rear seats (inside the car) that is used to access the shifter coupling. If the shifter seal is leaking, you will see a puddle there.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Martin3.2's Avatar
Sander, you're right, it's transmission fluid called Swepco.
Check your seals.
Martin
Martin
Old 04-10-2005, 05:06 PM
Friend of Warren
As it is a 911 it could be one of 3 fluids. Washer fluid, ATE brake fluid, or Swepco tranny fluid. All of which are blue.
Kurt V
Thanks all - sounds like it could be a few different things - I'll take a closer look...
'71 911E
Old 04-10-2005, 05:08 PM
