Oil Filler neck very loose
When changing out hoses today, I noted that my oil filler neck is quite loose. Wiggles a lot, and turns ever so slightly.
Is this common? How do I secure it? Jim
Jim Dean LL.B. - London, Ont, Canada. 1969 911T "Blood Orange" Euro (Brought over from Germany in 86) Engine and brake system rebuilds 2006 & 2007 "Oversteer scares passengers, understeer scares drivers." |
I would rather be driving
The filler neck is attached to the oil tank with a rubber connector and two hose clamps. Check the hose condition for cracks and tighen clamps as needed.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Thanks Jamie
