				pedal cluster rebuild-brake pedal spring
			What does everone do for the brake pedal spring when rebuilding the cluster?  The spring is NLA.  Does it need replacement?  What do rebuilding services do?  I guess I'm assuming that it's ok just to reuse the old one.
	Bill G. '68 911 Ossi Blue coupe  |
			Who says that they are NLA.  Part #90142353100 $9.95 in stock at Stoddard.  Mid America lists them in their catalog for $12.99 so Pelican probably has them.  The above part number is for the early car. You didn't say which car you needed the spring for.  The later spring 1978-1989 is #91142353103 and is cheaper.
			Jim
	69 911 2.3Ez 85 928S  |
			Jim, it's for a '72 cluster.  I was just going by the PP website, which indicates them as NLA.
			So that leaves the question: would you replace it as part of the rebuild?
			If my old one was very rusty I would.  If just surface rust, clean paint with black rust o leum and you are good to go.  I checked PP website after posting and was surprised at the NLA listing.  Sometimes only the dealer can get them.  Good Luck.
					Jim
