80 SC running lights blow fuse
My left side running lights are blowing fuses once in awhile. I don,t have a dead short as a fuse will keep the lights on several days. I recently started using a 16 amp fuse instead of the 8 and the problem persists. I don,t want to go any bigger as the wiring becomes the fuse.Any one see this before ,remember what the problem turned out to be?
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 04-11-2005, 04:59 AM
You've already made the wire the fuse....
find the *problem* and fix it !....don't EVER go to a bigger-than-standard fuse...especially in our under-fused cars !
Mom ( ...Wil)
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-11-2005, 05:10 AM
PS....long duration between fuses popping?....look at ALL connections...wires, bulbs, etc...and ensure all are clean and relube with dielctric grease when done...
Try that first...look also for obvious wire chafing or other distress...
Wil
Wil Ferch
Old 04-11-2005, 06:31 AM
