Heat/Vent Cable-Where to Buy?
Had a broken heater cable and need a replacement section of wire. The sheath is in good shape.
Did a search and couldn't find a previous thread I thought I saw on getting replacements at a bike shop? Checked locals shops and Home Depot/Lowes, and all they have are braided wire.
Other than factory wire, has anyone replaced their wire with aftermarket? (Thought I would go ahead and replace the three vent cables while I was at it, so I need quite a few feet.)
1978 911SC (not black, Mocha Brown)
Old 04-11-2005, 02:41 PM
Sumotang's Avatar
The heater cable is for sale on Pelican. Here is the diagram
http://www.pelicanparts.com/catalog/images/pedals/diag/pull_cable.jpg
Item No. C-424-701-02 and its $12.35
I presume you are refering the the cabe from the heater leavers tot the heater boxes.
Hope this helps
Damo
83SC 'Guards Red' - Sold
1994 993 C4
Old 04-11-2005, 03:08 PM
3.2 CAB's Avatar
I bought mine at a local lawnmower repair shop, they have several sizes, should have the right size you need, I posted something about it when I did mine, it was stainless solid wire, so I should not have to worry about it again, I bought enough to do both sides at least 2 times, was about 3 or 4 dollars total if I remember right. Check my previous posting on this. Good luck.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 04-12-2005, 06:04 PM
304065's Avatar
Here's one for you, the heater boxes for a '66 have been superceded, no surprise. Unfortunately the heater cable in '66 wasn't long enough, and didn't have the correct end fitting, for the later boxes. So mine are wired shut for max heat.
Anyone have thoughts on how to get the correct end and the correct cable length?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-12-2005, 06:23 PM
