-   -   Back Date Exhaust 82 SC o2 sensor ? (http://forums.pelicanparts.com/porsche-911-technical-forum/215755-back-date-exhaust-82-sc-o2-sensor.html)
cveres 04-11-2005 02:13 PM
I assume that you must locate the o2 sensor somewhere in the early exhaust when back dating the exhaust on an 82 SC. Do I put a bung just past the collector? Any advice or pit falls with this modification other than emmissions?
Rot 911 04-11-2005 02:16 PM
If you buy SSI's the 02 bung is already installed.
cveres 04-11-2005 02:19 PM
I have a pair of nice early heat exchangers. Where is your fitting located?
onsse 05-12-2005 01:11 PM
Hi,
sorry for being ignorant, but can some one explain on what is back dating?? Does it mean to completely remove the heat exchangers and replacing with headers??
can i do this on my 84 carrera?
~onsse
:confused:
jester911 05-12-2005 03:03 PM
Backdating simply means taking a later car to earlier car design. In this case backdating exhaust is going to pre 74 exhaust setup.
The search button will bring many things about this subject.
onsse 05-12-2005 03:05 PM
thank you.... will be researching... for more...:)
Bill Verburg 05-12-2005 03:11 PM
here's one I added to mine a few years back
http://forums.pelicanparts.com/uploa...1115935738.jpg
http://forums.pelicanparts.com/uploa...1115935797.jpg
onsse, yes but for your car the results are so/so. Emission inspection concerns can be a big issu as well.
a search will be fruitfull
juanbenae 05-12-2005 03:14 PM
thats the nicest "try the seach" slam ive ever seen. mr V plays well with others.
