Porsche Crest 1970 911T Trunk/ Gas Venting
I am trying to get a copy of the layout for the trunk venting&filter system. I purchased this car and have a bunch of loose hoses and the filters to go along with them. Are all these necessary? HELP if you can.
Thanks,
John :
Old 04-12-2005, 04:23 PM
304065's Avatar
Go to main pelican page
click on parts diagrams
click on early 911
click on fuel system 1
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-12-2005, 05:27 PM
RallyJon's Avatar
Depends. Are you trying to restore the evaporative emissions system to stock or just cut down on the gas smell in your garage?
I did the latter,running the vent hose from the tank up to the little black box collector under the driver's side trunklid hinge (part #2 in that diagram), then out to the fender and it cut down the fumes by 90% vs venting straight out to the fender.
993 · 911 · STI · S4 · rally car
Old 04-12-2005, 07:11 PM
Thanks for the help, Im new at this.
Old 04-12-2005, 07:31 PM
Early_S_Man's Avatar
Porsche Crest
John,
Here is a slightly more 'pictorial' diagram that may be helpful:
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-12-2005, 08:19 PM
That helps a bunch! Thank you!
John
Old 04-12-2005, 09:02 PM
randywebb's Avatar
your lines are probably toast by now - if you didn't plan to replace all of them then do so.
they should be flexible - if they are rock hard.. time to repalce them.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-12-2005, 09:28 PM
