removing a scratch from rear reflector?
I have a scratch on my rear reflector that I'd like to remove. I have read here that toothpaste might work. I gave up on that idea after about ten minutes since it didn't seem to be doing anything. What products are out there which will buff a plastic piece like this? Do I handpolish it or rent an orbital polisher? Any other smart ideas?
Thanks, Graham |
Meguiars makes some plastic polishing products of varying grits.
You can remove the deepest scratches by sanding w/ 400 grit until the scratch is gone, then using a polishing wheel with polishing rouge. It'll look like new.
Even 3M Imperial Hand Glaze...used to remove micro-scratches from paint...will work if the scratches aren't too deep or too bad.
I guess it goes without saying that you attempt to fix such things with as mild a "fix" as you think will work....and go to more aggressive means only if it doesn't work. Don't go too aggressive too soon. Wil |
There's a company called Novus that makes scratch remover for plastic/plexiglas. I used it in my signmaking business to repair customer property and it is a superior product.
meguires makes a 3 step plastic/acrylic/paint polishing/finishing system you can buy at a good paint supply store
is the scratch really that bad? my relatives in Germany love it when the front of their car gets wear and tear, its a sign that the car has been driven and used for what it is supposed to be used for. |
| All times are GMT -8. The time now is 08:05 AM. |
