Front a/c condensor-where does this plug into?
While disconnecting the remote radar detector sensor in luggage compartment, I discovered the front a/c condensor blower unplugged.
I see two white connectors but I don't have a clue which one receives the black plug from the blower.http://forums.pelicanparts.com/uploa...1113278893.jpg |
You could always just turn on the a/c and stick a voltmeter into each "mystery plug." If only one shows 12 volts, that's the one to connect to the blower.
Good idea, thanks scott.
| All times are GMT -8. The time now is 08:57 PM. |
