Mobil1 Transmission Fluid
I have an 87 Carrera that needs a transmission fluid change ASAP. My understanding is that Mobil1 is the way to go with the G50. A couple of questions:
- What grade do I need? - Does anyone have a good source? Our host does not seem to have it. Thanks!
Mark 87 Carrera Coupe, Venetian Blue / Blk Int. 04 Mazda 3i, Nordic Green / Tan Int. (commuter mobile) 04 Pacifica, Inferno Red / Tan Int. (family mobile) My Blog - Webini's World |
Hey Mark,
We are searching for the same thing, but different. I want Red Line. I looked through the archives and then talked to my trusted wrench and Red Line was the pick. Just an FYI, I have heard good things about both. Someone told me that Mobil 1 was readily available at any parts store. If I can't get Red Line, I may go Mobil. -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Mobil 1 gear oil only comes in one weight, 75W-90. That is the correct fluid to use in the G50. Should be available at whatever chain parts stores are in your area - AutoZone, Pep Boys, even Walmart. You'll need 3 quarts. Be sure you can remove the filler plug before you drain it! And watch your elbow - the fine threads on the plugs have a way of being very hard to loosen, the letting go all of a sudden.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
IMHO for a G50 it is hard to go wrong with either mobil 1 75w-90 or red line equivalent.
Andy |
What about an LSD G50?
Mobil 1 is LSD compatable. Got it in mine - no problems.
Agreed, the 1-qt 75w-90 mobil 1 sold in the US is good for a LSD or non-LSD G50. with the Red Line, you will want to get the 75w-90 GL5 which has limited slip additive, if you have an LSD G50. If you don't have an LSD, you can either use that OR the 75w-90ns GL5 which does not have a limited slip additive. In a non-LSD G50, it really doesn't matter, either is fine.
Andy |
This may be a stupid question, but is the 3 qt capacity the same for the LSD G-50?
Team California
Mark, That's not a stupid question at all, but the differential would not change the size of the transmission so the answer would be yes.
Denis |
That's what I thought, but I wanted to be sure.
![]() Thanks everyone!
