-   -   Help!! What have I done to my SC?? (http://forums.pelicanparts.com/porsche-911-technical-forum/216084-help-what-have-i-done-my-sc.html)
Kirk911SC 04-15-2005 08:11 AM
Cold control pressure was 65 psi (with the engine stone cold) - much higher than spec. System pressure 75 psi (normal), rest pressure 22 psi after 10 minutes (normal).
Car was bucking, backfiring badly, wouldn't rev, bad exhaust smell, hard to start, rough idle.
mb911 04-18-2005 10:33 AM
are you checking ccp with the wireing harness still conected?? if so you will see those numbers. I would guess your co is off wcp should be in the 55 range what is yours?? do you have ben watts cis book??
Kirk911SC 04-18-2005 10:46 AM
All the pressures are in the normal range with the new WUR. I still haven't got the CO set right yet, but the car is driveable, just down on power. I'll get it right eventually........still think I'm too rich.
Kirk
Paulporsche 04-18-2005 01:13 PM
If you search you can find the push/pull method of setting your CO, or you can adjust to the point just before the idle speed fluctuates, or (of course) you can have it set w/ a gas analyzer. JW likes 3.5%.
Rick Lee 04-18-2005 01:50 PM
But wouldn't a bad WUR only affect the first few minutes of drivability? I know my WUR is bad, but I just have to let the car sit for 1-2 min. after cold startup and then it's fine. I had had the mixture way rich, but the wrench brought it down from 5.25% to 2.25% and everything is MUCH better now. I guess I'll start planning on a WUR rebuild or tweak, but I can live with a 1-2 min. warm-up before taking off.
Kirk911SC 04-18-2005 03:26 PM
Warm-up regulator affects control pressure all the time.
I think mine was causing too high a pressure all the time, and causing a very lean run condition.
I tested the new WUR after install and it spec'd out perfectly.
