Broke
Westy's Avatar
Unhappy Pop-Offs aren't fool proof!
Well, not only did the pop-off valve blow to pieces, I cracked the airbox. I have no idea how or why this happened, but it did. Ahhh, the money pit has claimed yet another.
Anyone got an airbox for an 81 SC?. Anyone, anyone, anyone?
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 04-12-2005, 11:34 AM
vash's Avatar
schit!
i will call partsheaven and see what is up.
poof! gone
Old 04-12-2005, 11:41 AM
Weren't you having WUR problems? Did a backfire occur because of a bad WUR, or was a cracked airbox causing the symptoms that led you to think the WUR was bad when really it wasn't?
Old 04-12-2005, 11:42 AM
Broke
Westy's Avatar
I replaced the WUR, then the box cracked. Schitt, I don't know. I had the car sold, and obviously that sale has been terminated. The thing ran fine, it just needed a WUR. I know its mad at me for selling it. My SC is possessed.
93 968 Cab
Old 04-12-2005, 11:45 AM
vash's Avatar
brian, PH has some clean used ones for $150. let me know if you want me to drop by and get one for you.
poof! gone
The pop-off wasn't epoxied shut was it??
Broke
Westy's Avatar
You never stopp helping us, do you Cliff? That's 300 bucks cheaper than a new one. Yeah, when you get a chance grab one. I'll come down and wax your car, cut your lawn, and maybe do the windows.
93 968 Cab
Old 04-12-2005, 11:47 AM
Broke
Westy's Avatar
No, the pop off was working fine. It['s been in there for a couple of years. Owa Tagoo Siam. I surrender
93 968 Cab
Old 04-12-2005, 11:48 AM
vash's Avatar
ok, i will call PH and reserve one.
poof! gone
Old 04-12-2005, 12:58 PM
Hey Cliff,
Can you stop by Safeway for me too? I am getting hungry!
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 04-12-2005, 01:02 PM
Broke
Westy's Avatar
OOOH yeah, Safeway makes good sandwiches. And Cliff, while your getting me the airbox, get a pop-off valve and put it in. Make sure you use the correct epoxy. You know how much faith I have in pop-off valves!!
93 968 Cab
Old 04-12-2005, 01:07 PM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
Make sure you lubricate the rubber seal in there while you're at it. My car backfired and it popped the valve clean out of the hole where it was mounted! The rubber in the valve had been sitting in the heat of the box without being lubed and had bonded to itself. I put some lithium grease on it to keep it from happening again.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 04-12-2005, 01:55 PM
GOT TURBO..
MobileWrks's Avatar
here is what i was thinking. the dist head, either got stuck open,dumping raw fuel in the cyl. then on exceleration causing a back fire, or the pin in the head was stuck,once he punched the gas, no fuel was delivered to the engine causing it to be way too lean ***small mixtures problem wont cause that much damage***.... Any one disagree, going once, going twice......
Old 04-12-2005, 03:53 PM
GOT TURBO..
MobileWrks's Avatar
Fuel distributor- Control center, contains a regulator to keep system pressure constant. The main moving part is a central pin which is controlled by the air sensor plate. ** When the throttle is opened the increase of air into the manifold causes the air sensor plate rises and pushes the control pin into the FD which allows fuel out to the injectors. ** Mixture adjustment is via the 3 mm allen screw, turning the screw clockwise makes the mixture richer, remember lean "out".
Old 04-12-2005, 04:23 PM
vash's Avatar
ok, "SPECIAL SAUCE" on the sandwiches. extra for brian.
i blew my pop off valve once, just because the mix was off. to take out an airbox with popoff valve, would be one big mutha effa. so you are saying the airsensor plate was off center, causing the FD plunger to stick one way or the other? i think that could be easily determined by doing that magnet on the sensor plate thing. see if it moves smoothly.
poof! gone
Old 04-12-2005, 05:47 PM
im tellin' ya, the rubber seals in those valves bond together like glue...
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
Old 04-12-2005, 05:51 PM
GOT TURBO..
MobileWrks's Avatar
I did a car once and the sensor plate felt fine. Then i pulled off the fuel head and found scaring on the pin. Scuffed it smooth and then ran like a champ.....MM his pop off valve was fine. Pump hold pressures were on the low side but in spec. Set WAR pressures-controled (minor adjustment needed) Set timing. was advance by 6 degree to much. Sensor plate was dirty, cleaned up and was in the correct position. Hold pressures with not controled, did not hold pressures in spec. Prior to WAR installation, his car was running WAY TOO rich, plugs were black, aswell as splutter low to mid rpm. He said it ran fine until they went to smogged it. Dont know why it would happen a few days later after installing and setting all pressures......
Old 04-12-2005, 07:03 PM
cantdrv55's Avatar
Brian,
If you can't make it to Cliff's, PH can ship via UPS or I can get it from Cliff and bring it to Sac. I'll be at UC Davis Med Ctr on Tuesday.
Chris
Old 04-12-2005, 10:08 PM
Broke
Westy's Avatar
Thanx Chris. I don't guess there's any hurry. The next two weekends are spoken for, and this job requires a motor drop, so I'm just not all that jazzed about jumping in and doing it. Besides, I'll probably replace some seals and o-rings while the motor is out, so it's not coming out in the morning and going back in in the afternoon. Da bi*ch will be apart for a while.
93 968 Cab
Old 04-13-2005, 07:07 AM
