-   -   What does a cat bypass pipe get you? (http://forums.pelicanparts.com/porsche-911-technical-forum/216182-what-does-cat-bypass-pipe-get-you.html)
Moses 04-14-2005 11:29 AM
I have run every possible exhaust configuration on my car. I now run a pair of RandomTechnology catalytic converters.
Conclusions;
Before and after emissions show a staggering change in emissions.
Dyno shows no perceptible change in HP. Possible slight torque increase at lower RPM's with the cats.
Absolutely no increase in running temp with the cats.
juanbenae 04-14-2005 11:42 AM
your 3.6 is an entirely different animal though.
fastpat 04-14-2005 11:43 AM
Originally posted by ZOANAS
Because tree-huggers, like the rest of us, apparently, are being fed a load of crap about the ozone layer, etc., just so we can be forced to choke the crap out of our cars. It's all scientific mumbo-jumbo force-fed to us by the scientists who rely on the grant money from the government that passes the laws that require the emissions controls. It's the circle of life, Simba!
Drop the cat, Beavis, have it bronzed and display it proudly on your mantle. Do it just for the statement. I'll drink a ceremonial beer for you and toss the can in the Bay.
Truth, Amen brother!:cool: http://www.pelicanparts.com/support/...s/beerchug.gif
fastpat 04-14-2005 11:52 AM
Originally posted by cantdrv55
Didn't the native Americans back in the day call the LA basin, the Valley of Smoke? And, that was way before industrialization.
Global warming? Of course! Where else would the world's temp go from the Ice Age but up, duh!
The tsunami, in its short duration, caused more pollution in the region than the inhabitants themselves.
I'm with ZOANAS, it's the circle of life. Humans may be able to affect the natural processes but we are not the underlying cause nor are we the panacea.
Porsche content: go with the bypass and report the results, please. Thanks.
There's an interesting quote from the earliest Spanish explorers about the LA Basin's pollution phenom.
The EPA, founded by Richard Nixon, and the various federal and most state air quality laws today are all about power, controlling people, and stealing money from them.
:mad:
Emission 04-14-2005 12:00 PM
My 3.3 Turbo clearly ran 10-15 degrees cooler (oil temps about 175-180) without the CAT.
My turbo spooled faster too.
fastpat 04-14-2005 12:19 PM
Conclusions;
Please post photos of your installation.
Emission 04-14-2005 12:20 PM
Originally posted by SoCal911SC
Wasn't your cat high mileage/clogged, though?!?
Yes, good point. Mine was 130,000 miles and melted.
I still think it ran cooler sans CAT as the air (exhaust) wasn't restricted on the way out the back. It is pretty well known the turbo will spool faster without the CAT (dunno how much quicker though...).
Carrera3.5L 04-14-2005 12:24 PM
Some data points to chew on:
3.5L Motronic twin-plug motor that runs PERFECT
with stock heat exchangers & catalytic convertor:
HC @ 15 mph (PPM) - 13
MAX allowed - 121
HC @ 25 mph (PPM) - 8
MAX allowed - 96
CO (%) @ 15 mph - .04
MAX allowed - .76
CO (%) @ 25 mph - .03
MAX allowed - .65
NO (PPM) @ 15 mph - 283
MAX allowed - 807
NO (PPM) @ 25 mph - 290
MAX allowed - 746
Now, with headers installed & no provison for catalyst:
HC @ 15 mph (PPM) - 95
HC @ 25 mph (PPM) - 90
CO (%) @ 15 mph - .44
CO (%) @ 25 mph - .44
NO (PPM) @ 15 mph - 769
NO (PPM) @ 25 mph - 743
Conclusions? The motor still passes, but just barely!
1. Motor is down on power with stock heat exchangers and catalyst installed due to exhaust restriction.
2. Motor runs much hotter (not good) with stock heat exchangers and catalyst installed. Approximate oil temp at 210-220 versus 195-200 with the headers.
3. Removing heat exchangers & catalyst and installing headers significantly sheds weight. Even removing just the catalyst in favor of a pre-muffler will shed some unwanted lbs. and the car will run slightly cooler. BTDT.
Do what you feel is right and best for you.
Ralph
KobaltBlau 04-14-2005 06:54 PM
Conclusions;
Moses, do you have any photos of your latest configuration? All I found was the sharpie version:
http://forums.pelicanparts.com/showthread.php?s=&postid=593993&highlight=Random+T echnology#post593993
if you would rather not post them you could email me through the board.
Thanks,
movin 04-14-2005 07:27 PM
I tried ('87) both the straight pipe cat elliminator from Bursch and the Dansk premuffler. The cheapo Bursch gave a noticable performance improvement, especially top end, while the Dansk actually seemed to do nothing at all for performance and it weighed more... My vote is for what works, the Bursh straight pipe, at half the cost. BTW, good idea to have it aluminized because the paint it comes with just burns off in a few days allowing it to rust.
marcar911 04-14-2005 07:31 PM
Kevjandon,
I have an 82 911SC. When I got the car, it was fitted with an aftermarket converter and the stock muffler.
I have experimented with a Fab Speed pre muffler (flange welded @ incorrect angle - different story) as well as a Dansk single in dual out.
Summary:
1. Adding the premuff killed throttle perfomance. I now run the cat as top end is the same with increased throttle response and low end.
2. The pre muff was quieter. A little different sounding, but not loader.
3. I now run the cat with the Dansk for the best of both.
I have read that the Porsche version of the Euro Pre muff (Dansk same) performs better due to the volume of the enclosure. Fab Speed and straight pipe both have lower volumes. Might limit velocityandflow?
Additionally, keep in mind the O2 sensor needs heat to light off. Without converter, may cause issues.
Any newer style cat should flow well. Gains in removing the cat depend on how inefficient the unit is in the flow department as compared to the pipes, pre muffs, etc.
Marlin
Nine9six 04-14-2005 09:04 PM
Kev,
You musta been watchin the one on ebay that ended tonight...Were you the winner?
kevjandon 04-15-2005 06:36 AM
I considered it, but I elected to pass. Seems like money is better spent the muffler.
Carl83911 04-15-2005 09:11 AM
Re: Re: What does a cat bypass pipe get you?
Originally posted by KobaltBlau
Nothing, compared to a good metal-core cat.
___
Any problems with passing emmissions wht the metal core?
Moses 04-15-2005 09:20 AM
Re: Re: Re: What does a cat bypass pipe get you?
Originally posted by Carl83911
___
Not with mine. Great performance. Do a search for "Random Technology". I posted before and after #'s.
