Help need cam timing specs for a 74 2.7
I'm trying to finish a cam "re-seal" job.
I need the cam timing specs for my 74 911 2.7 motor. HELP PLEASE. Thanks in advance, Paul |
The setting for a 2.7 with cis is .4 to .54 mm.
Thank you Camgrinder, very much. Got it. Tomorrow, the thing should run.
Going to sleep now. Paul |
Your welcome
.4 to .54 mm. is for the "S" engine but if you have the 911 normal engine the spec is .8 mm.
Joe |
Thank you Joe.
Paul |
| All times are GMT -8. The time now is 08:12 PM. |
