-   -   '69 Center Tunnel Layout Question (http://forums.pelicanparts.com/porsche-911-technical-forum/216542-69-center-tunnel-layout-question.html)
Britain Smith 04-15-2005 01:38 PM
I am about to run the fuel lines on my car and I am trying to figure out where stuff goes. I have seen the picture below that labels the things that are in there, but where are the fuel lines supposed to be routes? What goes in that area labeled driver side conduit?
-Britain
http://forums.pelicanparts.com/uploa...1113597433.jpg
Britain Smith 04-15-2005 03:50 PM
Come on guys...I know there are people here that have put hard lines in there cars. Do you go through the little driver's side conduit or not?
-Britain
Britain Smith 04-15-2005 05:37 PM
Should I have choosen a better title? Anyone?
TimT 04-15-2005 06:22 PM
I believe the supply line goes through the driver side conduit, and a return line if you have one, goes up the passenger side conduit
DonMo 04-16-2005 04:56 PM
I just replaced mine in a 1984 3.2 Targa this weekend, both go down the driver side. I used a wire pull string and some joy dish detergent as lube to make the pull go easier. The string type pull sting broke when I pulled it through the rough hole. The pressure hose comes out the passenger side hole and the return out of the driver side hole. Both holes are on the driver side of the tunnel. Do a search on tunnel fuel leak, that should get you some more hits.
