Driving member
CouldHelp/exhaust leak cause erratic idle/stalling?
I did a search and came up with nothing conclusive.
I just last week changed my exhaust to a 1 in 2 out muffler and europremuffler. Stock heat exchangers. Car ran perfectly before change. Now it has erratic idle and when going from dead start in 1st it will sometimes try to stall. I can't seem to detect any leaks but doing a search I came up with symptoms similar with a vacuum leak. Will an exhaust leak act the same way as a vacuum? I did no other mods at all before so it seems it must be the exhaust. Also for reference I have had a cat bypass on my car for the last 4 years before I went to premuffler. It had an O2 sensor in the bung but has never been plugged in. I set up the premuffler the same way.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. Last edited by jester911; 04-16-2005 at 05:28 AM.. |
Driving member
bump
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Driving member
Okay guys,
I know it is a little slow today but .... Anyone...Bueller
Driving member
19 years and 17k posts...
Did you knock a vacuum hose loose?
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Driving member
Unless there are vacuum lines under the car, no. I never opened the engine lid. Everything was underneath.
