Rodney Nelson's Avatar
Identify this Front Suspension
Hi, I need help identifying my front suspension. It was on my 1972 however the entire thing was front dated and now I'm bringing it back. I'm trying to determine what is good and she be refurbished.
So, my questions are...
what year is this suspension off?
Is it better than stock?
Or what do I need to know?
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold
Old 02-15-2020, 02:23 PM
What you have there is early underbody sway bar 911 - 1974-ish. Usually we see these with an aluminum rack support, but your's has the steel tube version. Hmm.... this is speaking 1976 912E to me
nothing trick about it. Measure the thickness of the sway bar. Its decent use on an otherwise totally stock pre 73 car
oh and very important! You are missing the clamps and bushings that attach the bar to those skinny extensions off the tube
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 02-15-2020, 02:30 PM
It’s like a later from 74 or later with the later front sway bar. The early ones used drop link through the body
Bruce
Old 02-15-2020, 02:32 PM
Registered Minimalist
75 911s's Avatar
Looks like my stock 75 suspension with steel crossmember - except gray instead of black
Old 02-15-2020, 03:12 PM
Looks exactly like my '74 as well.
Old 02-15-2020, 06:41 PM
Location: behind the redwood curtain, (humboldt county) california
Looks like my 74 with a 20 mm Carrera bar.
Old 02-16-2020, 07:15 AM
So based on what everyone seems to be saying this is a 74+ version with the sway bar that the 1972 did not have.
So, should I just use this one? Is it worth sandblasting and powder coating? Or should I sell this one and buy another style/used one and have that powder coated?
Thank you everyone for your inputs!
Old 02-16-2020, 01:59 PM
cycling has-been
bkreigsr's Avatar
Originally Posted by TRE Cup View Post
...Hmm.... this is speaking 1976 912E to me ....
FWIW - my 912E has a through-the-body bar. It is not on the original window sticker, so it's probably either a dealer add on, or later modification.
Old 02-17-2020, 12:28 PM
ILXLR8's Avatar
The 912E has an aluminum crossmember, so what you have is not E.
Looks like 74-75
Old 02-19-2020, 03:07 AM
Hi Rodney
Without knowing if the bushings or ball joints are "recent", I wound pull it apart to rebush, replace the ball joints and check the torsion bars for wear marks.
This makes the powder coat operation more effective at sealing up the metal, plus possibly upgrade the t bars if you are going to drive it hard.
If you are going to get serious with competition, you might want to ditch the undercount bar and go with a through the body anti roll bar for adjustability and ease of upgrading the bar itself.
chris
Old 02-19-2020, 05:57 AM
Originally Posted by chrismorse View Post
Hi Rodney
chris
HI Chris,
Thank you for your reply. I'm not going to use my car for competition just for the street but I want it to handle better than a standard 72T if possible. It sounds like you are saying that through the body torsion bars are better? I am definitely planning on pulling all of the bushings out and replace. And while they are out get everything powder coated. Should I try to find an aluminum one instead? or is the Steel one I have fine? Should I try to find a used though the body set up. money is a factor, so if not much gain, should I stay with what I have?
Thanks,
Rodney
Old 02-19-2020, 06:52 PM
