Quick rear hub question
Hi Guys
I'm half way through a DIY rear bearing repacement (full write up comming) and I have just pressed the hub into the new bearing and I cant work out how to tell if it is all the way in. The hub went in quite easily with the DIY press until a certain point and then it went very tight and I couldnt wind it in any more. The part I used to pull against on the other side of the bearing was half of the old inner race from the old bearing and it didnt look like it was preventing the hub going any further so I dont think it is that which is snagging it up. Maybe I have it all the way in and im just fretting but I cant really see how to see if it is????? Any help most welcome Thanks in advance |
ive just had another look, is it the fitting of the halfshaft that makes it all pull up tight or do I need to endure the hub is fully seated before fitting the halfshaft?
Please help, im almost there.... |
| All times are GMT -8. The time now is 07:35 AM. |
