-   -   cis co for sc?? (http://forums.pelicanparts.com/porsche-911-technical-forum/216978-cis-co-sc.html)
mb911 04-18-2005 10:16 AM
cis co for sc??
I set my co yesterday for 3.0-3.5% as everybodies recomendation and I am not sure that I get the throttle reponse and power with say 2.5% the Ben watts book says if no decal to set 1.5% as default what is your experience??
Paulporsche 04-20-2005 10:05 AM
Unless you have to meet an emission standard, why not just set it for what feels best to you?
mb911 04-20-2005 10:08 AM
I want to make sure that it does not run to lean.. I reset it and it runs better now 2-2.5% works best
Paulporsche 04-20-2005 10:15 AM
If the 1.5% default wasn't too lean, then your 2-2.5 won't be. Are your control pressures/WUR ok? Are you experiencing any lean start or run symptoms?
fred cook 04-20-2005 11:18 AM
CO settings....
I have the CO set at about 2.5% on my '80 SC. It runs well and gives 17-18 mpg in town and 25-27 mpg on the interstate. I also am running with the O2 sensor unplugged. Hope this helps.
