WydRyd's Avatar
Angry Windscreen Wiper keeps blowing fuses!
Guys,
How often do the windscreen wiper motors in these cars die?
I'm having a problem where mine keeps blowing fuses immediately! Can this be a dud motor, or relay? Perhaps a wire come loose and is shorting?
It happened whilst driving home one night in light rain. It just siezed on me
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-11-2005, 08:36 PM
WydRyd's Avatar
Any ideas guys???
Merv
'89 911 Turbo Cab
Old 08-13-2005, 06:06 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
First you should do a load test. This will tell you if the motor is going bad and pulling too many amps. Also (rare but not unheard of) is to make sure all the linkage is well lubricated and operating smoothly.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 08-13-2005, 06:28 PM
WydRyd's Avatar
Thanks Kevin.
I actually ripped out the whole motor assembly this weekend, found nothing wrong, re-installed and it now works! What a PITA!!!
Must have been a bad wiring connection that was corrected when I re-installed the whole thing.
However, I now find my intermittent switch doesn't work. Maybe that was the problem all along? Perhaps a dodgy switch?
Merv
'89 911 Turbo Cab
Old 08-14-2005, 03:04 PM
