randywebb's Avatar
grease starter gear?
I installed a one of the light wt. high torque starters on the 1986 engine in my 1973T. It whined a lot and finally broke. On removal it definitely looked like it was hanging up (not disengaging from the flywheel gear). I have it rebuilt and ready to install. I think the rebuilder might have changed the gear on the starter.
I am wondering if I should use any grease on the gear to help it engage/disengage with the flywheel gear? I don't want to get grease on the clutch tho!
If so, what kind of grease should I use and how much? I'm a little gun shy about having the starter fail since I spent a huge amount of money to get this engine and modify/rebuild it...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-19-2005, 10:52 AM
Air Medal or two
afterburn 549's Avatar
well....I might be wrong or crazy,,I allways put a little of my favorit goop on...........(.chassie lube)
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 04-19-2005, 01:00 PM
ianc's Avatar
I wouldn't grease it at all. You'll get clutch disc dust flying around in there and turning the grease into a nice abrasive paste in no time. Not disengaging sounds like an issue with the original starter or ring gear...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 04-19-2005, 02:55 PM
I always use some axle grease. Keep it off the teeth. And besides it's not like you live in a dry world up there.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-19-2005, 03:07 PM
