-   -   Need Help! Warm Starting Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/217068-need-help-warm-starting-problem.html)
MikeS 04-18-2005 06:37 PM
My 84 Targa is having warm start problems! I've done a search and found the fuel check valve or the accumulator (on SCs) can cause this. Just replaced the check valve but the problem persists. If the car sits overnight - no problem starting in the am. But leave it 4-8 hours and two or three cranks are required before she fires up. Any other suggestions as to what can be causing this?
Thanks-
Mike
