-   -   cis question,never ran into this problem.. (http://forums.pelicanparts.com/porsche-911-technical-forum/217090-cis-question-never-ran-into-problem.html)
MobileWrks 04-18-2005 08:53 PM
The fuel dist head is off a different cat,i believe the engine is a 79, to a 75 chasis. WAR is new, head was bought from ebay. when the engine is under cranking and running, here is what goes on..........
Sensor plate splutter erratic ( sounds like a small toug boat )
only idles if timing is far advanced ( still spluttering,electronic points )
Some plugs,dark and dry,a few dark and wet,one wet no carbon,( Fuel head is adjustable,im thinking someone may have tampered with it...)
With old WAR, car was at 1 bar hot and idled, but ran like junk if drivin -
Fuel pump pressures good, WAR new,head bought used,or do i need to have the head sent out to match enginedoes anyone know who does FD tuning with it off the car???????
fintstone 04-18-2005 11:06 PM
apparently these guys do (no affiliation)
http://www.fuelinjectioncorp.com/products/distributors.php
MobileWrks 04-19-2005 09:41 AM
THANKS>>.i found the problem..... head is one, also the entire system is miss matched......
