-   -   OBD-II scanner/reader (http://forums.pelicanparts.com/porsche-911-technical-forum/217154-obd-ii-scanner-reader.html)
tycharle964 04-19-2005 07:35 AM
Hello,
Anyone have any luck purchasing and using the OBD reader from pelican?
Anyone reccomend a better one or if the reader is even worth it?
It is only 150 bucks, figured what do I have to lose?
Tyler
POKDUB 04-19-2005 08:01 AM
Look at www.scantools.net
Loads of free software will run on this OBD II box.
addictionMS 04-19-2005 09:30 AM
this worked for me
http://www.autoenginuity.com/
CBRacerX 04-21-2005 08:50 AM
Harbor Tools makes one that I bought - cheep and works well.
Bill Verburg 04-21-2005 10:33 AM
Baum tools has one that does OBD1 & 2
tycharle964 04-21-2005 02:16 PM
thanks for the replies
ordered one for the shop yesterday, now we need to find an old bum laptop that has a serial port and not USBs
thanks again
MuffinMan 04-22-2005 05:50 AM
Or you could get a serial to USB converter. They are around $20-$30, I believe.
code7rpd 05-26-2005 09:54 PM
Will any of these work on a porshe 993 motor? I have a euro motor from a 1995 993 and adapted the 16 pin diagnostic port on the DME. The Bosch Hammer works on scanning the DME but I am looking for a more cost effective solution. Will the AutoEnginuity program work or the scanttool for my application?
Thanks.
mmasse 08-10-2006 12:11 PM
Hi code7rpd,
Wher you able to get an answer for this issue. I am in the same situation and wonder how you solved it.
code7rpd 08-10-2006 12:41 PM
Mario,
I was able to figure it out from the wiring diagrams and installed it prior to selling the car. I may have written the instructions down. I will see if I can find them and I will let you know - I may have posted them on this forum but I don't remember.
mmasse 08-10-2006 12:58 PM
Thanks a lot...hope you find those.
GeorgeM 08-10-2006 12:58 PM
EBAY. Got my Actron for $70. Nice tool to have.
mmasse 08-10-2006 01:01 PM
George will this work with my engine?
mmasse 08-10-2006 01:14 PM
Hi code7rpd,
I found Moses thread on this issue but still have some questions.
http://forums.pelicanparts.com/porsche-911-technical-forum/150218-how-use-obdii-diagnostic-port-3-6-transplant-post2748755.html#post2748755
If you find your note it would be great, thanks again.
ruf-porsche 08-10-2006 03:11 PM
Brought one at HF for 39 bucks. Check out the diagnostic port on my cars that have OBDII All car came back with no code.
Don Plumley 08-10-2006 03:37 PM
Originally posted by addictionMS
this worked for me
+1
GeorgeM 08-10-2006 06:59 PM
If it has the standard OBD II connector, it should work. Not sure if it works with OBD I.
