-   -   Carrera would not Start (http://forums.pelicanparts.com/porsche-911-technical-forum/217167-carrera-would-not-start.html)
Ned nyna 11 04-19-2005 08:59 AM
All,
It was sitting on the rollers for the emissions test and then would not start. So , pushed it off the rollers and coasted out to the parking lot.
The hood light worked but the dash was dead. battery had 12 volts and the ground connection was not tight at the battery.
So I looked up under the dash and found a wiring plug that had opened. It carries the wires from the ignition switch through the firewall.
And I am now living happily ever after.
Carrera owners, check that plug.
Ned
