bouncing oil pressure gauge in 85 carrera
Anyone know a quick fix for the oil pressure gauge needle bouncing slightly from 4-2 bar range. The oil pressure is consistently where it should be but I'm wondering if cleaning the contact between the sender wire and sender or connections behind the gauge and the gauge would be the cure for the bounce?
Is it a sign of impending failure of the sender (located in the middle of the engine and hard to get unless engine dropped?).
Old 04-22-2005, 05:37 PM
Automotive Monomaniac
Emission's Avatar
Clean the contacts, or replace the sender (that's what I did).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 04-22-2005, 05:42 PM
Happened to me. the contact point was loose. Clean them and shove it back in there. The problem went away.
Good luck.
Jeff
Old 04-22-2005, 06:59 PM
could be cavitating. add oil. had one 6 qt low recently with a jumpy gauge.
206 637 4071
Old 04-22-2005, 07:32 PM
oil level is not the problem, dipstick is accurate measure . I keep oil level just above low mark at idle after warmup on level ground.
Have to try cleaning contacts in time
Old 04-24-2005, 05:55 PM
