-   -   Bilstein struts raised spindles + gussets done by 911CTS (http://forums.pelicanparts.com/porsche-911-technical-forum/217412-bilstein-struts-raised-spindles-gussets-done-911cts.html)
DW SD 04-20-2005 03:21 PM
Guys,
I bought these Bilstein struts from MuffinMan and had them shipped to Clint Smith for modification. The spindles were raised 30mm for my RSR look project. I wanted to lower the car that much but retain the porsche A-arm / strut geometry. My 17" wheel will allow for this height modification.
Clint turned the strut housing raised the spindles, re-welded them and gussetted the spindles, per the original RSR style. He then painted them with a super-hard epoxy - based paint, which matches the original Bilstein green. I'm thrilled!!
He's also building a sweet bump steer kit based on metric heim joints and over-sized components (compared to what's out there).
Clint has also been building some fuchs - centered 3-piece wheels, as well.
Clint is a great guy. Just thought you may want to look him up, if you are doing something similar.
You could email him at iceman8911@yahoo.com OR look him up through 911CTS Pelican member name.
These are the struts:
Doughttp://forums.pelicanparts.com/uploa...1114035541.jpg http://forums.pelicanparts.com/uploa...1114035560.jpg
