-   -   rebuilding the airbox (http://forums.pelicanparts.com/porsche-911-technical-forum/217440-rebuilding-airbox.html)
Rondinone 04-20-2005 05:58 PM
After chasing a lean misfire for two months I pulled the entire CIS setup to find a crack in my airbox. After reinstalling the engine last January I had a huge backfire the first time I started it, and the car hasn't run right since. Here's the offending crack along the right seam:
http://forums.pelicanparts.com/uploa...1114044165.jpg
So I put a sharp knife in the seam and tapped it all the way around to separate the box into two halves. It didn't look like it originally, but probably half the seam was blown out.
http://forums.pelicanparts.com/uploa...1114044343.jpg
Oops, looks like we had a pretty big fire in here!
http://forums.pelicanparts.com/uploa...1114044534.jpg
There's an interlocking channel that goes around the box. I cleaned it out with a dremel and then wire brushed all the surfaces that will get glued:
http://forums.pelicanparts.com/uploa...1114044692.jpg
Since the box is nylon, I think, and most epoxies don't stick well to nylon, I had to look around a bit to find something suitable. Devcon makes a plastic epoxy for nylon called "plastic welder II". Not cheap at $33 for four of these tubes, but still better than $450. You can tell by the industrial label that this is not your average home depot epoxy.
http://forums.pelicanparts.com/uploa...1114044837.jpg
The epoxy was thick, yellow, and smelled worse than any glue I had ever used. I had to mix it out in the driveway it was so overpowering. I laid a heavy bead all the way around and sealed her back up. A little dental mirror and a flashlight verified that the goo had squeazed out of the seam all the way around the inside of the box:
http://forums.pelicanparts.com/uploa...1114044976.jpg
It goes back in this weekend. I'll post whether or not it worked.
azasadny 04-20-2005 06:13 PM
Great work! I made a small repair to my airbox 18 months ago and it hasn't leaked since and no more backfires! Hope yours goes as well...
Nitrometano 04-21-2005 06:24 PM
I use for one 911 3M marine silicon 5200 and works great.
afterburn 549 04-21-2005 07:24 PM
Nitrometano! hay thats what I was gonna say!.....try the stuff,, Talk about hold pwr. and still will let things flex if needed!!!!!!
Nitrometano 04-21-2005 07:31 PM
I repair the air box 2 years ago and no problemas. 3M 5200 Silicon works great!!!
wswilburn 04-22-2005 06:14 AM
I also repaired my airbox about 2.5 years ago using an automotive silicone rubber. I found the original screws had taken a bit of plastic with them and would no longer tighten, but the closest english size (6-32 or 8-32 I think) was just slightly bigger and fit well.
Chuck Moreland 04-22-2005 08:58 AM
I have an old airbox, from a 77. The bottom section that is cracked in yours is perfectly good on mine.
If you want to buy that instead of the glue (or the glue fails), contact me.
Rondinone 04-22-2005 09:12 AM
I'll keep that in mind. I'm putting it back in this weekend, we'll see how it works.
It appears that the airbox is made up of some kind of composite. I'm now leaning more towards polyester than nylon. I put a bit of the epoxy on an open spot on the bottom of the box as a test. When I yanked the epoxy off the next day, it took a layer of plastic with it. The "bare" spot looks fuzzy like fiberglass. I'm guessing it will hold.
Rondinone 03-09-2007 04:55 PM
OK, been almost 2 years and still holding!
Dan in Pasadena 03-09-2007 05:16 PM
Good work, BUT....you can buy good used airboxes for $125, I did with a WTB ad here. Granted that is more expensive than the $33 of glue, so that's worth a try but the good used boa is more of a sure bet. Also, I don't see a popoff valve in there. Unless I missed it, you are going to install one aren't you? $50 and I never worry about my airbox anymore.
Last, if you HAVE to glue an airbox, what about that "miracle of miracles" J-B Weld?
Rondinone 03-09-2007 07:10 PM
2 years ago I could not locate a used one. Bad timing I guess.
Pic 3 is the bottom of the pop off valve. It got blown right out of the box. There's nothing like an out-of-phase ignition to blow the hell out of a box.
J-B weld might work, but I picked this epoxy because it is specific to plastic.
