flipper's Avatar
spaghetti and all that jazz
I finished freshening and cleaning the motor and decided to get rid of all the tape on the wiring harness before I put the fuel injection back on. I put the wiring in that black wire tube stuff. Well, as I was taking the tape off, I found a nasty mess of clipped and clamped wires. some were even exposed and touching. As you can see in the picture, I do not have the black plug that these wires fit into and I am wondering if anybody knows what color wires goes on what # pin on the other side of the 14 pin connector?
2005 911 carrera
57 BMW r50, 2007 Ducati s2r 1000
2007 Boxster (sold)
77 2.7 911s chocolate w/ducktail (Mr Hankey) (sold)
77 930 black (sold)
Old 04-30-2005, 07:35 PM
len911's Avatar
This might help... It was from an SC to Carrera conversion article...
T 14 3.2 (88)
1 yellow / starter 50
2 red / source from alternator 30 ( or B+ )
3 green - black / Oiltemperature Instrument
4 green - red / Oiltpressure Instrument
5 red - green ( depends on year ) / from ign. to backuplightswitch
6 gray - brown / backuplightswitch to lights
7 free ( used with Turbo )
8 brown - black / temperature switch for the fresh air blower
9 green - white / Oiltempressure idiot light
10 free ( used with Turbo )
11 blue / alternator control light 61 ( or D+ )
12 free ( used with Turbo )
13 black - yellow / power source for the fresh air blower
14 red / source from alternator 30 or B+
In the wire schematic this connector is named T15. On the body from the
connectors are the little numbers stamped in, if not the 1 is at the end
with the code nose.
T 14 2.7 (74)
2 green / only used with sportomatic runs behind
the instrument for the overheat idiot light
5 green - yellow ( depends on year ) / from ign. to backuplightswitch
6 gray - black ( depends on year ) / backuplightswitch to lights
7
8
9 black - purple / to tach
10
12 brown / to Regulator D-
13 black / to Regulator DF
brown - white / Sportomatic power source
blue - yellow / Sportomatic shift lever contact
yellow - black / Fresh air blower
red - white / to CIS and fuelpumprelay
Good Luck! Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 05-01-2005, 05:42 AM
