-   -   Help With Wiper Wiring Sequence (http://forums.pelicanparts.com/porsche-911-technical-forum/217891-help-wiper-wiring-sequence.html)
tom1394racing 04-23-2005 02:28 PM
I reinstalled my wiper motor assembly today. I am not sure of the wiring sequence. I took a guess, based on the relative postions of the wires in the wiring diagram.
http://forums.pelicanparts.com/uploa...1114291169.jpg
Position 1 - Black/Yellow
Position 2 - Blue
Position 3 - Black/ Purple
Position 4 - Red/White
The ground wire was obvious and is underneath the wires in the photo.
When I switch on the wipers, I get nothing with the stalk clicked up one notch. In the second notch I get normal wiper speed with no return to rest position when the stalk is moved to the off position. In stalk position 3 I get nothing.
Can some one give me the correct wiring sequence so I can avoid having to play a guessing game?
len911 04-23-2005 05:18 PM
Tom, there should be numbers at each of the connectors... Just wired my '74 a few weeks ago... 5 wires all together.
Green to 53i, red/white to 53a, blue to 53e, black/yellow to 53b and black/purple to 53...
My connector is different... Turns out my 74 motor was burned... Got one from a mid 80s Carrera and connector was the same. Don't know what year is your car.
Hope this helps some... Look for the numbers. Lou
tom1394racing 04-23-2005 06:13 PM
I'll have to take the wiper assembly out to see the numbers. There are no numbers visible looking through the clock hole in the dashboard. I was hoping someone could save me the trouble.
PS...Yes I know that I should have thought of this before I installed the wiper..Live and learn.
tom1394racing 04-24-2005 02:43 AM
Doesn't anyone have an old wiper motor laying around that they could check the terminal numbering for me?
BTW it's a '73.5 911T wiper motor. I'm going to try the old "mirror under the motor" trick to see if I can get the terminal numbers before I remove the motor.
tom1394racing 04-24-2005 03:09 AM
Never mind guys. I found this disassembly photo in my archives. I was able to figure things out from there and wipers now work fine.wuhttp://forums.pelicanparts.com/uploa...1114337303.jpg
