DP935 member
kycarguy 935's Avatar
Porsche Crest older Road and Track article on a DP 935
I found this online and thought I would share and to add to pelican archives for others searching for DP 935 info. Not sure of the year it was written but think it was around 1979.
DP 935
Fantasies fulfilled, no waiting.
What's your most outrageous automotive fantasy? Being strapped into the beak of a 917 as it screams along the Mlsanne straight, clawing for speed without end? Being the center of automotive attention, experiencing vicarious adulation in a machine that inspires universal respect? Perhaps you're turned on by the thought of mastering a car so potent, so lethal, that any serious mistake is likely to be your last. Or do you simply wish to rise above your peers by driving a car so far beyond the capabilities of the four-wheeled masses that you will feel like a god on wheels?
Here's a car that can fulfill every one of these fantasies with startling realism. The DP 935 started lifes as a Porsche 930, but has been transformed into a roadgoing facsimile of a racing 935. The fiberglass panels that accomplish this were flawlessly executed by Designer Plastics Automobilbau, the bodywork couturier of Kremer Racing, among others. The oversize rear spoiler; the hopelessly low, curb-fouling, deeply ducted front air dam; the tiny, aerodynamic, nearly useless mirrors; the running boards; and the broad, multifariously vented fenders combine to create the 935 look convincingly enough to freeze knowledgeable car lovers dead in their tracks.
Inside the DP 935, the competition imagery continues. Although the sumptious Porsche leather interior is retained, a serious go-fast ambiance is imparted by the oversize boost guauge; the pure-racing, perforated-aluminium dead pedal; and the very businesslike adjustable boost knob directly astern of the shift lever. A pair of Porsche sport seats are comforatble and suppotive enough to locate the passengers against the omnidirectional accelerations this car produces. No sound system is provided, or particularly missed; sensory overload is already ensured by the DP's raspy exhaust, over-the-nose-cone-view, and heavy thrust.
Generating this thrust is a DP modified engine. The carefully assembled stock 930 motor was ripped apart and blueprinted to stricter-than-Zuffenhausen standards, the heads were ported and polished (along with the turbo's inlet housing), and the compression was bumped up a tad. peak boost is set at 16 psi, more than 3 psi higher than in a stock 930. The engine was also emissions-certified in America with a catalyst in lieu of the muffler; this modification substituted a sharper rasp, though not much louder, for the standard 930's whooshy sound. It did no, however, permit the engine to run on any unleaded fuel that we could find, so we resorted to heavy transfusions of octane booster to keep detonations at bay.
Our miscreancy was rewarded with rocket-sled performance. The DP 935 lunged from a standing start to 60 mph in a mere 4.6 seconds, 100 came up in but 10.5 seconds, and 130 was only another 8.8 seconds away. It scorched the quarter-mile in 12.8 seconds at 112 mph. But even these fabulous figures don't convey the car's sheer thrust. The DP 935 delivers an incredibly strong shove in the back, and the punch never seems to quit. Even at 120 mph it pulls harder than a Scirocco at 50. Not until well past 140 mph does your breath come back and the acceleration of this juggernaut fall to a familiar level.
In light of this tremendous proclivity for speed, the car's peak of 162 mph is a bit disappointing. But with the DP's fifteen-inch tires (the stock diameter is sixteen inches), the engine is revving well beyond its power peak at top speed. The exhaust-plugging, after-market catalyst probably didn't help the power curve past 6000 rpm either.
Ther smaller-diameter tires are part of the DP 935's chassis meliorations. Porsche forged wheels, eight and eleven inches wide, front and rear, are shot with 205/50VR-15 and 285/40VR-15 Pirelli P7 gumballs. The suspension is lowered and stiffened as well. These changes firm up the ride considerably, but the motion left within the limited suspension travel is fluid and supple. Like the rest of the car, this suspension feels best in triple-digit speed ranges. It also happens to work around corners; on the skidpad, we measured 0.84 g of stick, the best we've ever seen on a roadgoing Porsche.
These landmark performance measurements bolster the DP 935's postion as a paragon of automotive omnipotence. And for a mere $95,000, Richard Buxbaum of Classic Motors in Chicago can make it yours. That may seem a bit high, but fantasy fulfillment never comes cheap.
--Csaba Csere
Vehicle type: rear-engine, rear-wheel-drive 2-passenger, 2-door coupe
Price as tested: $95,000
Engine type: turbocharged and intercooled flat 6, aluminum block and heads, Bosch K-Jetronic fuel ingection
Displacement: 201 cu in, 3299 cc
Power (SAE, net, estimated): 390 bhp @ 5500 rpm
Transmission: 4-speed
Wheelbase: 89.4 in
Length: 170.0 in
Curb Weight: 2910 lbs
Zero to 60 mph: 4.6 seconds
Zero to 100 mph: 10.5 seconds
Zero to 130 mph: 19.3 seconds
Standing 1/4 mile: 12.8 secs @ 112 mph
Top speed: 162 mph
Braking, 70-0 mph: 179 ft
Roadholding, 282-ft-dia skidpad: 0.84 g
Road horsepower @ 50 mph: 13.5 hp
C/D observed fuel economy: 17 mpg
Old 04-23-2005, 10:41 AM
Light,Nimble,Uncivilized
Check this thread to see the DP 935 that showed up at one of our monthly gatherings.
Drago
'69 Coupe
R #464
Old 04-23-2005, 10:49 AM
DP935 member
Thanks for that Drago.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 04-23-2005, 11:12 AM
Designer King
Paulporsche's Avatar
Thanks. FWIW Csaba Csere wrote (and writes) for "Car and Driver".
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-23-2005, 12:13 PM
Kantry Member
oldE's Avatar
If I'm not mistaken, when Road & Track wrote about the DP 935, their editor had taken it to some sort of reunion, and referred to the car as "the Atomic Cockroach". Do you suppose that made an impression on a young man?
Les
Best
Les
Old 04-23-2005, 01:58 PM
The article about the high school reunion was by Larry Griffin...also from Car & Driver.....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-24-2005, 06:58 PM
