-   -   What's Wrong with my 911? (http://forums.pelicanparts.com/porsche-911-technical-forum/218068-whats-wrong-my-911-a.html)
86 911 04-24-2005 05:28 PM
I have a 1976 911 cabriolet (conversion) with a '79 3.0 engine in it. Today I went out to start the car, and I turned the key, I heard the fuel pump was running, which is normal, and then when I attempted to start the car, I heard a "click" and the car died. I tried re-starting it, but it was totally dead. Nothing happened. The fuel pump did not run or anything. I went out to charge the battery, but the battery was fine. Could this be a starter or solenoid problem?
Thanks!
patkeefe 04-24-2005 05:38 PM
Do you have the other normal functions with the key on, such as the waning lights, etc? Do the headlights come on? Radio playin' some forgotten song?
Pat
350HP930 04-24-2005 05:39 PM
It could be a bad electrical connection such as a battery terminal connection that is corroded and/or not tight.
86 911 04-24-2005 05:55 PM
Thank you for your suggestions. I played with the power cable, and it was loose, and now the car starts fine. Thank you again for your help. Maybe my 400th post brought me the luck? ;)
