Veriprime question
Hi,
I am just wondering if a little veriprime showing through the filler primer is ok to paint or if I need to go over with filler (2K) primer again. Every so often I will cut through the 2K and a spec of the yellow verimprime will be visable. I have been recovering but am thinking, maybe I do not have to for small dime size spots. Thanks, David |
I paint directly over variprime on fiberglass parts, works fine.
Sorry, I am a but slow on this stuff. So will the same apply for metal? I did a bumper last year with just veriprime, (before I knew better) and didn't seem to have any problems a year later.
Thanks, David |
Yes, you can top coat over the Variprime,the 2K does not need to be re-applied.
Ed |
Great, that makes my life much easier.
Thanks, David |
| All times are GMT -8. The time now is 06:01 AM. |
