-   -   Ground strap condition a problem? (http://forums.pelicanparts.com/porsche-911-technical-forum/218241-ground-strap-condition-problem.html)
wazzz 06-19-2024 02:00 AM
Originally Posted by AlBackus36 (Post 12207705)
Non-conductive slime on it can certainly affect the performance of the braided strap. It's an exposed braid that relies on contact between the strands to provide the overall gauge.
If you swap it out, you can get covered/sheathed 2/0 cable with heat shrunk ends to replace the braided type. A battery shop or similar should be able to build it for you if you can't. Clean both contacts on the trans and body, and install the new strap with dialetric grease or something to keep future moisture out. Never worry about it again.
I don't think so. Each strand, as small as it can be, carries its load of current and it doesn't matter whether strands are in contact with each other, so long as they total the required gauge and so long as they are all in contact at each end of the strap. They can be covered in slime and will still carry their part. Litz wires, such as those used in inductions heaters and induction cookers are built this way. Each strand is insulated separately and doesn't contact other strands, and the sum of their individual gauges carries enormous amounts of current. Of course the contact points at each end still need to be dead clean with no trace of corrosion.
brighton911 06-19-2024 04:40 AM
It will clean up like new if you first clean the grease/oil off with thinners then immerse the strap in pickling vinegar (10%) for a couple of hours.
NickW21 06-19-2024 07:02 AM
Originally Posted by E Sully (Post 12268376)
It was intentional and it prevents issues. To reduce vibration the plate uses rubber silentbloc mounts. The plate and components need a chassis ground and it eliminates static charge issues. A ground strap is needed (911 612 008 00 Ground strap plate on your SC).
If you are having issues with your aftermarket EFI system, you will need to review the installation documentation.
Thanks for confirming Ed! Since my car has passed through a few hands prior to me owning it, I just wanted to confirm it was in the correct placement! On to other potential areas for possible grounding issues!
Best,
Nick
PeteKz 06-19-2024 03:58 PM
I don't care if my ground strap is greasy. IMO, it helps prevent corrosion of the strap and at the contact points. You do you.
John W. 06-19-2024 09:42 PM
Totally agree with Wazzz, a dirty ground strap is ok. Be sure it isn’t frayed as that reduces the current flow capacity and is bad. The electrical contacts must be clean. Don’t use dielectric grease on the contact places, use a conductive grease.
