zymurgist's Avatar
[Fuchs] Anyone ever build their own buffer?
I'm going to be polishing my Fuchs sometime in the near future, but one of the things holding me back was the fact that I don't own a buffer. I buffed a Corvette wheel (simpler shape than a Fuchs wheel) with a buffing wheel mounted in a drill a few years ago, but it sure seemed to take forever.
I was at Carlisle last Friday, and I found a really neat piece of hardware... it's an axle with two bearings and a pulley that is designed to be bolted to a surface, connected to a motor via a V-belt, and used to mount two buffing wheels. I remember when I was a kid, a friend's father had built a bench grinder using a similar setup, but I've never built anything like this before.
I have the axle assembly and a 2 horsepower motor (came out of my old air compressor). Has anyone here ever built a similar device? I'd appreciate any tips, tricks, etc. The guy who sold me the buffing supplies said that I will want to keep the RPM around 3000 (if I remember correctly)... this is the approximate design speed of the motor.
Ken
1974 Porsche 914 2.0 "Babydoll"
Old 04-26-2005, 02:01 PM
dweymer's Avatar
Don't worry, have a homebrew. For wheels I would make sure to extend the shaft at least 10". If the motor design speed is what you want to run, then each pulley should be the same diameter.
Donnie
Currently Porsche-less.....
Old 04-26-2005, 03:26 PM
