Sameer's Avatar
Yellow Thriller!!
Engine components:
X 3.4 litre(98mm) RUF BTR/CTR1(Yellowbird) 7.5:1 compression piston/cylinder kit(Mahle) fully finned, short skirt pistons
X "Euro" fuel injection (no oxygen sensor/Lambda control, and 6mm O.D. fuel lines to the injectors)
X Engine balanced and blueprinted
X RUF Group B Cams
X Racing Valve springs with Titanium retainers
X 38mm billet injector blocks with Phenalic insulators
X Bosch high pressure 996 GT2/044 962 Racing fuel pump
X Complete engine gasket set with Viton seals
X Raceware headstuds
X ARP Rod Bolts
X Polished cylinder head ports
X K29 Ruf Hybrid Turbo
X Kokeln 642 cubic inch racing long neck intercooler(polished)
X Tial 46mm wastegate with 0.9 bar boost spring
X Bailey Highflow Billet Diverter Valve/Blow off Valve
X EVO Motosports High flow air Induction Kit, air filter housing painted in Guards red
X Mille Miglia stainless steel free-flow dual outlet muffler with 4 stainless steel tail pipe
X 1 5/8" B&B nearly equal length stainless steel headers without heat exchangers (Based on Porsche 934 race car)
X Dome-shaped, spun aluminum CIS venturi plate
X Andial fuel enrichment set at 3rd step(Same as M148/RUF fuel enrichment)
X 3.6-3.8% CO level,24- 25 deg. ignition timing
X Running on Caltex RON 98 unleaded(Super)fuel, 80 litres fuel tank capacity
X Mobil 1 5W-50 Fully synthetic engine oil
X Broquet Fuel Catalyst (8 x B/8T in tank units)
X B&B fender mount w/Electric fan oil cooler, steel braided hoses
X Custom fabricated front bumper mounted oil cooler with high-pressure oil hoses
X Rear Compact oil cooler
X Cool collar around oil filter
X Samco silicon hoses
X Zinc coated fuel lines, pulleys etc..
X Polished fan ring and fan wheel
X New Bosch factory injectors, fuel lines, xenon headlights, rearlights, seals etc..
Transmission/Brakes/Suspension components:
X 930/934 Gearbox using SWEPCO 210 oil
X KEP Lightweight billet clutch(3500 pounds clamping force)
X RUF short shift kit
X 993 twinturbo brakes(big reds) with steel braided brake line
X RUF CTR1 Sport Nurburgring shocks front and rear (Bilstein)
X RUF anti-roll bars/sway bars (front 23mm, rear 22mm)
X Sanders engineering gun drilled tubular torsion bars (front 22mm, rear 30mm)
X Strut tower brace/bar welded to body
X Das Sport Weekenders Bar, approved by PCA Club Racing, stock class cars painted in matt black.
X Weltmeister Monoball Camber Plates
X Weltmeister steering rack spacers
Body/Cosmetics:
X RUF Speedline rims(limited production) painted to Porsche black(Rear:285/40 17x10)(Front:235/40 17x9)
X RUF BTR/CTR1(Yellowbird) front and rear bumpers
X RUF front bumper rubber lip
X Gemballa carbon fibre rear spoiler with integrated deck lid(RSR 3.8 type)
X Front air inlet for oil cooler and brake ventilation
X Air inlets instead of fog lamps
X Factory option code XB7-Rear air ducts(for the rear brakes)
X RUF pedal set
X RUF instrumentation with silver bezels
X 964 Nappa leather style dash in yellow stiching, Billet ignition cover
X Carbon Fibre instrument panel(behind gauges)
X RUF 3 spoke suede steering wheel
X Door trim panles as in 911 Carrera RS with leather cover and coloured handles and pull straps in Guards red
X RS Guards red seat belt
X Recaro A8 light weight, limited edition leather seats with new seat rails, seats back in Speed Yellow
X Philips Xenon headlights, 993 Horn
X Techart clear side markers
X 964 style windscreen wipers
X Ruf CTR1(Yellowbird)/934 Aero mirrors
X 993 G/Knob and Handbrake in Carbon Fibre finish
X 964 door sills with Turbo script
X RUF factory decals
X RUF BTR 3.4 Carbon fibre emblem in center console
X Alpine CD player with Boston Acoustic rear speakers
X No rear seats, no rear seat belts, no spare tyres, no tools, no rear windscreen wiper, no headlight washer, no sunroof, no water tank for wiper system, no fog lights,no front speakers, no carpets, no AC, no centre console
X Leather roof liner
* Full car rewired and restored to factory specifications (including under carriage, full paintwork, floor board, seals etc.) All work carried out at RUF Automobiles Singapore.
Speed Yellow 911 Ruf BTR Conversion
PCS Membership No: 266
Rennlist Membership No: 050315-5911
Ebony Black 2004 Jaguar XJ6
Titanium Grey 2003 Ford Focus
Old 04-26-2005, 04:25 AM
Sameer's Avatar
Old 04-26-2005, 04:28 AM
Doog's Avatar
awesome....
1971 2.2T
1992 Lancia Delta HF Integrale Evoluzione
Old 04-26-2005, 05:18 AM
Wavey's Avatar
All that AND a Cool Collar!
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 04-26-2005, 05:59 AM
PorscheGuy79's Avatar
Send a message via AIM to PorscheGuy79
When reading over this, "The Hand of God" comes to mind for some reason.
Matthew
Sometimes the questions are complicated and the answers are simple.
Old 04-26-2005, 06:05 AM
That is an awesome car. What does it dyno at these days?
You could get about 90% of the performance with just the cool collar though.
Kidding.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 04-26-2005, 06:09 AM
Sameer's Avatar
Thanks for the compliments guys, have'nt had it dynod yet but I'm looking at somewhere in the 450fwhp region.
Old 04-26-2005, 08:16 AM
Yellowbird RS's Avatar
Great car.
Congrats!
X/A
Old 04-26-2005, 09:25 AM
( scratching my head )
Old 04-26-2005, 09:33 AM
Administrator
Jack Olsen's Avatar
'FWHP' means flywheel horsepower, I think -- unless there are some serious drivetrain mods that don't show up in the picture.
Old 04-26-2005, 10:05 AM
randywebb's Avatar
More like a kick in the rear from the Foot of God...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-26-2005, 10:10 AM
vash's Avatar
holy kamolee. i just got back from singapore. too bad i didnt skip the night safari, and check out this car instead!
poof! gone
Old 04-26-2005, 01:36 PM
Detached Member
Hugh R's Avatar
No A/C?? Forget about it!! Seriously, I don't even know what 3/4 of that stuff is that he listed.
Hugh
Old 04-26-2005, 01:58 PM
Sameer's Avatar
I'm already loosing weight sweating in the car without the AC..
Old 04-26-2005, 07:04 PM
Licensed User
Shuie's Avatar
where is the redline on the tach? I thought the YB rev'ed out at 5500-6000RPM
****ING awesome car, BTW!
Old 04-26-2005, 07:20 PM
Licence number is ominous... car from hell ?
Old 04-27-2005, 02:11 AM
Sameer's Avatar
Once again thanks for the compliments guys.
Old 04-27-2005, 08:35 AM
randywebb's Avatar
Mark of the Beast!
Old 04-27-2005, 09:20 AM
twobone's Avatar
Speedo!!!!!1
a 350 KMH speedo.
Hmmmm thats 217 MPH I think.
That makes a serious statement of ballistic intent!
Old 04-27-2005, 10:17 AM
Sameer's Avatar
Well I've hit 300km/hr once, still pulling but I backed off.
Old 06-19-2005, 07:10 AM
