Dimensions of a 911
Found a trailer that's very light (680 lbs) but small. Not sure if the 911 will fit. Does anyone have the dimensions of a 911?
What I'm looking for is the width (to outside or tires) and the length of the car... I'm not at home right now (on the road) otherwise I'd just crack out the tape measure. |
I know for an early short wheelbase 911 you need about 14 feet.
I figure you would be safe with a 18ft by 8ft trailer. Not much side room or extra length but is should fit. |
Re: Dimensions of a 911
Track front: 1371 mm 53.97 in Track rear: 1359 mm 53.50 in Length: 4290 mm 168.89 in Width: 1613 mm 63.50 in Kerb weight: 1080 kg 2380.98 lb |
Thanks Jeremy
| All times are GMT -8. The time now is 07:48 PM. |
