PPI leakdown & compression results. Opinions?
Just got the results of the leakdown and compression tests done on the 72E Targa I'm looking at.
#1 16% 120psi
#2 20% 120psi
#3 21% 130psi
#4 12% 130psi
#5 11% 125psi
#6 12% 125psi
These were done cold, cranking at approx. 300 rpm, batteries a little weak. Original 2.4, 86K miles, no major work done on engine judging by receipts since original owner. Runs strong and pulls hard to redline, no smoke on startup or when goosed.
Any opinions on these results?
Dave
1969 911T Coupe
1972 911E Targa
Old 04-26-2005, 10:35 AM
From a novice:
Compression is uniform = GOOD
(I don't know what they should be as far as PSI for that engine)
I thought the leakdown test should be around 8% or lower, so those numbers seem high to me. Also, there is a pretty big spread between cyls#4,5,6 and #1,2,3......
Others will provide more insight I am sure.
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 04-26-2005, 11:47 AM
GOT TURBO..
MobileWrks's Avatar
The engine should have a full cranking power. Also those #'s are low, Did they give it a full throttle upon cranking?? 10% and lower...
Suggestion.. Drive it around,give some good and high RMP's, go back and redue the leak down.. Maybe he drives it like a turtle, and has build up around valve seats....
Old 04-26-2005, 11:54 AM
anthony's Avatar
I thought that this test should be done warm. Why was it done cold?
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 04-26-2005, 12:07 PM
IROC's Avatar
IMO, leakdown numbers would be more representative if taken when the engine was warm. Compression numbers look nice and even.
I'd be happy with the numbers, myself...
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-26-2005, 12:09 PM
GOT TURBO..
MobileWrks's Avatar
it does not matter what the compression results are, its a leak down that is more critical..... Last post.. RPM's hahahah
Old 04-26-2005, 03:48 PM
Nine9six's Avatar
I agree with MobileWrks...Take the car out and bring to full operating temp, and give it a good spirited drive. This should give you realistic leakdown #'s, as it allows the engine to blow any loose carbon deposits out and away from the valves. Have your wrench listen for where leaks are eminating, as this is a telltale indicator of exhaust or intake leaks, and what type of work may be needed.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-26-2005, 04:18 PM
Thanks for the input, guys. This was a prelim check, since the car's several hours from me. I'll be going there this weekend to drive it and revisit the leakdown.
And I'll be sure to give it some RPM's (or RMP's).
Dave
1969 911T Coupe
1972 911E Targa
Old 04-26-2005, 06:39 PM
Early_S_Man's Avatar
Porsche Crest
The results are meaningless and inconclusive!
Engine is supposed to be fully warmed up, battery is supposed to be fully charged!
And, without a note indicating where leakage was heard on the bad cylinders, i.e., at intake snorkel, exhaust pipe, or breather tube at oil filler ... the results are useles!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-26-2005, 10:46 PM
