Headlights no workie ?
I have an issue where my headlights no longer work but they do come on when the bright lights are applied.
For the last year when I turn on the ignition, the speedometer and headlights would not turn on unless I giggled the ignition key. Now the headlight won't come on period. They again on come on when the brights are applied. I cannot lock the headlights in bright mode either. The speedometer does work after the key is giggled. What most likely is the culprit and is it an easy fix? Car: 85 911 Targa |
The low beam and high beam are on seperate fuses. If not the low beam fuse then it might be the high/low stalk switch.
David |
Sounds like a bad stalk switch. You can buy them from our host.
Also, this would be a good time to install the Sucro relay kit. Good luck!
1984 Targa |
I had the reverse problem (flashing brights would turn lights off) and a new switch from PP fixed it.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
Agree with Scottb that you probably need a new stalk. You could probably pull it and look at the switches but its probably terminal.
Get a knew one and the relay as suggested and it should last longer than the original.
Damo 83SC 'Guards Red' - Sold 1994 993 C4 |
Bad stalk...our host sells them.
-Jeff
Jeff |
