Longhoods Unite!
PhatRedHead's Avatar
Send a message via AIM to PhatRedHead Send a message via Yahoo to PhatRedHead
Joe's lil resto project for the last 3 years
3 YEARS AGO IT LOOKED LIKE THIS...
and this...
and this...
NOW WHILE A GUY WAS BEATIN ON THE BODY AND PUTTIN IN NEW ROCKERS AND A FLOOR I DID THIS...
AND IT KINDA CAME OUT PRETTY, BUT I'LL DRESS IT MORE LATER...
NOW MIND YOU, IT AIN'T DONE...BUT HERE IS WHERE IT STANDS AT THE PRESENT...
ALONG WITH MY TOP MECHANIC...
ITS MADE A LITTLE MORE PROGRESS THAN THE LAST PICTURE, LIKE THE DOORS ARE FINALLY COMING TOGETHER, HEADLIGHTS ARE IN AND WORKING. AND JUST GONNA LAY THE DASH AND FRONT GLASS IN PROBABLY THIS WEEKEND. IT'S MADE ITS MAIDEN VOYAGE DOWN THE STREET AND BACK A COUPLE TIMES JUST TO PROVE TO MYSELF THAT IT WORKS. BUT THE CARBS AND IGNITION TIMING NEED SOME MAJOR LOVIN' SOON.
BY THE WAY THE COLOR IS A BMW COLOR, STEEL GREY METALLIC, I SAW IT ON A E46 M3 AND KNEW IT WAS THE COLOR. THERE ARE ALOT OF PICTURES I LEFT OUT AND ALOT MORE I SHOULD HAVE TAKEN WHICH WOULD HAVE SAVED ME ALOT OF HEADACHES...OH WELL. I WILL TRY AND TAKE SOME MORE PICTURES OF THINGS SOON.
SORRY FOR THE IRREGULAR PICTURE SIZES AND CAPS, I'M EXHAUSTED RIGHT NOW AND YEAH...THAT'S MY EXCUSE.
1970 911T -- Neglected, oil burning problem, batman smoke
1974 914 2.0 Weber'd -- new project!!
**My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
Old 04-26-2005, 09:56 PM
DP935 member
kycarguy 935's Avatar
Its going to be worth all the work. Keep up the good job and it will look great when finished and very fulfilling.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 04-26-2005, 10:33 PM
Zeke's Avatar
Criminey! I thought I had a rat to bring to life. You have every bit of work that I did and more. Funny, you have rust on the dash and everywhere else, but the lower chassis at the fender supports looks good. So does the battery box. How'd that occur? Mine was Swiss cheese all along there.
Great job!
Old 04-26-2005, 10:38 PM
Can't think of a better project during those Minnesota winters. I really admire what you have accomplished. Tell us more about the motor. Those carbs really came out nice.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 04-26-2005, 11:07 PM
Longhoods Unite!
after pulling basically everything else out of the car, we decided working or not the motor was coming out and getting torn down. started taking at apart and what do i find??? a cracked piston, good thing i didn't try running that motor!!!
here is the piston, i cleaned it up and it stays on my desk...
got a replacement piston and had a bunch of machine work done to the motor, pistons honed, heads got new valves and guides, cam towers got worked around a lil bit, but mainly we did all the work that we could, we assembled the whole thing ourselves (dad and lil brother and i). we did all new bearings in the case, new rings, ya know, the usual stuff
here is partly together with the pistons and cans on...
the carbs came out great for two reasons, my lil bro meticulously taking pictures as he took them apart, i swear there are at LEAST 50 pictures of those carbs before and during disassembly. the second reason, i bought a parts washer, and we really didn't mix the stuff the way the bottle said and basically used straight cleaner instead of alot of water in there....hey so it ate away the gloves on my hand if i was in it for a while, but crap got clean QUICK. this was a early T car so it had the marelli dizzy on it, not a cheap thing to find these days but cheaper than buying a new bosch one. so that's still there.
the suspension and brakes got a complete refresh. new ATE slotted rotors, rebuilt the calipers myself, designed an interesting way to remove caliper pistons using air and almost smashing fingers. repainted the calipers and here is how they turned out...
hopefully it stops
its sittin on new konis, stock torsion bars in front and RS's in the rear i think, i forget what size they are but are significantly bigger than the originals.
but when we got to the right rear torsion bar, we saw that the torsion bar tube was tears away from the unibody...bad day...
basically we had to have that side of the tube rewelded with sleeve in it and then that sleeve welded to good metal in the unibody. (this is what i get for having a Mechanical engineer as a father and all his buddies over to look at the problem..."IT WON'T FLY, BUT DAMNIT IT AIN'T GONNA BREAK" ( one of my dad's favorite things to say when building ANYTHING) we had to have the new poly bushings taken down a couple thousandths on that side to accomodate for the patch work we had to do.
but they're all in and its stiff, i ended setting the bars too low and now the car its wicked low, i can't get my fist under it with how it sits right now. might be a problem with the crappy driveway that we have.
time for class!!! ahh!!! man i love accounting /me shakes his head no...
Old 04-27-2005, 06:18 AM
}{arlequin's Avatar
bump for a nice resto. great car, good work. what are the specs on the motor?
dave
1973,5
Old 04-27-2005, 07:44 AM
....really porsche related.
What kind of dog do you have? He/ she looks like my dog I rescued from St. Croix.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 04-27-2005, 07:59 AM
Former Options Trader !!!
Car looks great I wish I had the skills that many of you folks have. Options trading skills traded for mechanical skills... any takers?
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 04-27-2005, 08:04 AM
Crusty Conservative
silverc4s's Avatar
Great looking targa!!! Please keep posting pics as you go. It is really enjoyable AND educational to see these old babys go back together..;-)
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 04-27-2005, 09:15 AM
Longhoods Unite!
just a 2.2 with the zenitch carbs on it, i'm gonna run no air box and hopefully just those socks over the velocity stacks. new headers, not so impressed with those, the powerder coating is already flaking off that crap...and a manta muffler.
the black beast is a black lab, just turned 2 a lil while ago, we got her when she was just a fuzzy ball of black fur and could hardly walk. gets more attention than anyone or anything in this house, spoiled rotten i tell ya. we NEED to run her around and wear her out AT LEAST 4 or 5 times a day or she just starts crying or being a super pest to everyone, but its all ok once you throw a tennis ball for her. for a fact though, she is faster than my quattro, my durango and damn near beats my bike when i race her up the street. we'll see how the porsche is when it gets running.
replaced the shift linkage bushings last nite, feels ALOT Better, if i don't have to work too late tonite i might go tackle the rest of the driver door tonite.
we'll see...
it's nap time...
Joe
Old 04-27-2005, 12:42 PM
}{arlequin's Avatar
cool. wish I could hear that muffler.
dave
1973,5
Old 04-27-2005, 12:46 PM
Longhoods Unite!
the carbs and ignition are not tuned yet, but just driving it up and down the street a couple times sounded great !!! i will get some video up as soon as i get some
Old 04-28-2005, 08:43 AM
I would rather be driving
jpnovak's Avatar
Great project. Its good to see another one brought back from near death.
Where did you get the filter socks? I assume they are just foam caps with a hose clamp. I am looking for something similar for my EFI project.
Old 04-28-2005, 09:31 AM
Work in Progress
Rich76_911s's Avatar
TAKE'EM, SOLD. Only problem is my mechanical knowledge is, "lefty loosie, righty tighty." Which is equivalent to my option trading knowledge, "buy low, sell high."
Old 04-28-2005, 09:57 AM
Wow, I saw those first pictures and wondered how you got a hold of my pictures to my car-Very similar condition. Cool.
Old 04-28-2005, 10:21 AM
Longhoods Unite!
they are motorcycle airfilter socks, made by UNI, pretty decent price if i remember. not a fan of the "green" color but hey, if they work, i'm happy.
Old 04-28-2005, 11:49 AM
