WUR relationship to CO %?
Is the 3MM mixture adjustment screw on top of the fuel head an air or fuel adjustment? I ask b/c I just changed my control pressure regulator (WUR) and now the car is eye-watering rich. The presssures are now within spec. I'd guess I need to lean out the mixture now? Make sense?
Ken
1986 930 2016 R1200RS
Old 04-30-2005, 03:03 PM
ianc's Avatar
It controls mixture. When you screw the 3 mm in, it causes a greater deflection of the piston in the fuel dist for a given motion of the sensor plate. Back it off a little,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 04-30-2005, 03:35 PM
Designer King
Paulporsche's Avatar
When seen from above, counterclockwise is leaner. Unless you have a meter, back it off in small increments, say 1/16 turn @ a time, until the idle speed doesn't fluctuate. Your idle speed will probably then rise, so lower it by turning the idle screw clockwise.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-30-2005, 09:28 PM
