How to remove rear view mirror?
Hi,
I'd like to get some help with removing the interior rear view mirror... I know that the base is glued onto the windscreen & the mirror slides on the base. But, how do you slide the mirror off? Is there a set screw? A tab I need to pry? Or ??? Trying not to crack the glass. thanks... |
I have a recessed screw in the bottom under the mirror.
| All times are GMT -8. The time now is 12:35 PM. |
