Camber in question
I need advice from folks who have set ups for modified 911s. The car is a 1975 911S3.6 with F22 R29 Sanders Torsion bars, Adj spring plates, Polybronze bushings, SRP adj sways, Revalved Bilsteins, turbo tie rods, strut brace...Camber is now -1.2 F and -1.5 R running Michelin Pilot Sport Cup tires. Pyrometer shows a range 0f 129-157. Michelin suggests 160-220. Also, are any of you running hotter temps on the inside (20 degrees diff) of the tire compared to outside for better stick? The tires are just not heating up.
thanks,nick
911S/GTS4
964 C4
1987 Carrera 3.2
Old 04-28-2005, 05:10 PM
