Convert axles from 100mm to 108mm?
Car is a 1979 911SC
Is it possible to change my axles from 100mm to 108mm? Would it require new transmission flanges and/or new axle stubs to accomplish this? Thanks,
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) |
108 turbos would be too short
108 Carerra's might work if you changed the flange on the trans to 108 Why are you doing this?
Thanks Todd I drank what? = Party out of bounds - PriceLESS - BudWIZER "Boy Im gonna burn you a new one! - A new what officer?" = night in jail 993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
The why would be that I need a new CV joint or two and thought about just changing the axles when I saw some 86-89 Carrera style axles for sale at a decent price.
It's probably not worth the trouble. Rob
I think those would work but you would need to change the flanges on the trans
Some flanges from different trannies do NOT interchange. The splines are completely different.
If you were making a sand rail or something, maybe it would be worthwhile... But not for your use. Trust me - I spent a lot of time messing with this issue on older year cars. You might luck out with the newer ones, but maybe not.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
