9elf's Avatar
starter motor not disengaging
Hello Porsche ladies and gentlemen,
Please help.
My starter motor will not disengage. Normally when I turn the key I get the engine lights, I can hear the fuel pump and then I turn the key to the start position - the engine fires and the key returns to the last position.
Now the starter cranks and the engine fires at the point that the engine lights used to come on. Thus it appears the starter solenoid is always energized when I get to this second last turn point on the key. Do I need a whole new key locking mechanism or just the electrical switching piece that screws into the back of the ignition key lock?
Thank you in advance
Old 04-30-2005, 08:15 PM
randywebb's Avatar
Is this one of the light wt. high torque starters?? I had a problem with mine like this.
Try going directly from the battery to the solenoid and see if the problem continues...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-30-2005, 11:23 PM
Could be your ignition switch at the dash as well. If the spring return portion has failed you will have to turn the key back to run yourself or else the starter will stay engaged.
Easy fix though
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 05-01-2005, 05:23 AM
9elf's Avatar
Thank you gentlemen, I have ordered a new ignition switch and electrical pin from pelican. I just hope they get to me before Saturday so I can get to the track.
1977 911S
Old 05-01-2005, 04:14 PM
