Correct NGK for my car?
1978 SC....
Pelican recommends- BPR5ES
After searching the archives, it seems that several members here use the BP7ES w/ no problems.
I'm sure either plug will work fine.....but what would be my best bet as a daily driving plug in West Virginia?
Aaron
1978 911Sc
Talbot yellow
Old 05-01-2005, 07:39 PM
Licensed User
Shuie's Avatar
I used a BPR6ES for a drive or two last summer. This may be an apples to oranges comparison, but they were too hot for a 2.4 MFI motor. BPR8ES worked much better.
Old 05-01-2005, 08:05 PM
copper's Avatar
I use the BP6ES with good results.
The difference between the BP and the BPR is the added resistance to the plug with the BPR to reduce EMI. If you don't have any problems with interference with any other electrical stuff, the BPs will do just fine.
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 05-01-2005, 08:10 PM
Thanks guys.
No resistance problems.....so I'll probably go with a BP.
Aaron
1978 911Sc
Talbot yellow
Old 05-01-2005, 08:56 PM
