Wildman Emeritus
Exhaust Hell
If there is a Hell, I will bespending eternity as a Midas or Meineke employee!
Spent several hours yesterday with a Dremel & carbide deburring cutter removing 2 bolts from the cat/ heat exchanger flange in an effort to replace a broken shield bracket. What a PITA! I literally had to machine the bolt shanks from the flange because they had corroded into place & couldn't be punched out after the nuts were ground off.
Due to access/ angle issues, I removed the caliper, rotor, heat/dust shield & removed the lower connection of the shock. What I had planned on taking an hour or 2 took me close to 6 hours, not including a trip to work to raid the tool crib for the deburring bits. Were I not so stubborn, I probably would have quit & taken it to my wrench where he would have used a double secret technique & had it done in 10 minutes.
Now back together & operational but what an ordeal.
Anybody got an easier method for future projects like removing the cat & inserting a bypass pipe?
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 05-02-2005, 10:26 AM
Nine9six's Avatar
Yeah Mike, but now the job is done! Hopefully you applied anti-sieze compound to the fasteners to reduce future frustration. There is no "easier way" on rusted fasteners. I give it one shot with penetrating oil, heat, and a wrench. If it strips, out comes the cut-off wheel. Been there, done that...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 05-02-2005, 11:21 AM
Detached Member
Hugh R's Avatar
Try the Sears "Bolt-Out" sockets, as advertised on TV by Bob Viela. They're sockets with internal biting teeth, and they really work.
Hugh
Old 05-02-2005, 12:24 PM
try a hot wrench next time. 2 minutes.
206 637 4071
Old 05-02-2005, 12:52 PM
Wildman Emeritus
JW;
What is a hot wrench? Not familiar with this term.
Torch???
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 05-02-2005, 01:47 PM
torch. just slice off the head of the bolt or nut when they're not wrench friendly.
206 637 4071
Old 05-02-2005, 03:26 PM
