billwagnon's Avatar
door strike plastic broken - 73
The white plastic inside my door latch / strike is broken. What does the plastic do? I see there are complete replacement strikes, but the rest of the part is good. Can I get just the plastic?
Old 04-02-2005, 06:09 PM
pwd72s's Avatar
http://d240157.u39.zeonhost.com/forum/showthread.php?t=5053&highlight=broke
Old 04-02-2005, 07:26 PM
HarryD's Avatar
Paul,
Thanks. I was looking for that link but couldn't remember where I saw it.
and they say the memory is the second thing to go. The first is.......
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-02-2005, 10:59 PM
billwagnon's Avatar
Paul,
Was this a PB-Blaster kind of thing? Are the threads behind the bolts open to the rear wheel well?
Thanks for the help.
Old 04-04-2005, 09:37 AM
Yes, the bolt ends do protrude into the wheel well and do get very gunged up with debris. If they haven't been loosened in years they will need to be treated carefully. I stripped out the head of one and had to drill it out in order to remove it. Clean the bolt ends very well and PB blast them in advance. Make sure the 12 point fits tightly into the bolt head and go slowly. You can do it!
Old 04-04-2005, 10:08 AM
billwagnon's Avatar
does our host sell these? I've searched and can't find them under "door latch" or "door strike".
Old 04-29-2005, 02:53 PM
Search "door striker plate" They even mention a rebuild kit and something about plastic. HTH
Old 04-29-2005, 08:31 PM
billwagnon's Avatar
cool! I thought consensus was there were no rebuild kits. That's great.
Old 05-02-2005, 11:58 AM
