Where to get this brake line
Its item #18 as shown on the parts diagram/brake line.
didn't see it in this on line catalog. thx, |
Charles,
Its hard to tell which line you are looking for. If you can post a copy of the diagram and your model year, it might help. If you are getting the diagram from a parts manual or PET, there should also be a part number. You can search on Pelican with a Porsche part# and you should get a match. If not call Pelican with the number and they will likely be able to help you. Joe |
If it's the hard line running from the caliper to the soft line best bet is to cross over to an Audi unit. (because they are no longer availble) Requires a little manipulation though. If it's the long line that runs from the T to the right front soft line you'll have to use Napa for the same reason stated above. Measure the length and make sure you let them know what kind of threads you need. There's an outfit in NY that can make you any type of brake line. Can't think of the name off the top of my head but should remember the name I post it here. Good luck.
| All times are GMT -8. The time now is 08:49 AM. |
