911gilley's Avatar
WUR Fuel Line
Just woke my SC project car up from a long winters' nap in the barn.....but noticed a cracked line that our host doesn't seem to stock.
Can anyone confirm the Porsche part number for the half metal/half plastic fuel line that runs from the top of the fuel distributor to the warm up regulator (I believe it is the fuel pressure control line) on a '83 SC? I think it may be a 911 424 551 02. Below is a picture (courtesy of Aigel from a previous topic):
Hope I can get this straightened out so I can fire her up!
Thanks in advance.
Ed
_________________________
'95 993 Cabriolet
'83 911 SC Coupe (gone but not forgotten)
'84 944 Coupe (willed to brother)
Old 04-18-2005, 09:14 PM
David's Avatar
If it's item 61 in the pic it's E 930 110 513 00
Old 04-19-2005, 03:54 AM
DavidI's Avatar
I got one of those hoses from TRE in North Hollywood. Give them (Jeremy) a call, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 04-19-2005, 04:10 AM
I think he's talking about item 51 in the picture. I just had my off this weekend checking fuel pressure spec's with my gauges. I could be wrong, but I think it is all metal, with the half going towards the WUR being covered by a rubber outer layer. However, I'm not completely sure.
Mike
2016 Porsche GTS Club Coupe (60th Anniversary)
2007 Porsche GT3; 2014 Porsche Cayman S
1981 Porsche 911 SC; 1988 Porsche 944 Turbo S - Silver Rose
2010 Audi Q7 TDI; 2002 Audi A6 4.2 ; 1971 El Camino; 1966 Chevelle SS 396/360 HP; Spec Miata racecar
Old 04-19-2005, 07:04 AM
911gilley's Avatar
It's actually number 51 in photo, and it is approx 3/4 metal from the fuel distributor and 1/4 rubber hose with a plastic core on the WUR side. I think there were two different part numbers, one for SC's through 1980, and another for SC's 1981 and up. Maybe the difference is that one is all metal and the other is only part metal.
Ed
'95 993 Cabriolet
Old 04-19-2005, 07:21 AM
Designer King
Paulporsche's Avatar
On my engine, hose 51 was semi rigid black plastic that matches the fuel injector lines, although possibly a different diameter. If NLA, you could fab your own w/ material from McMaster Carr. If you search you will find a lot of help from others on how to do this.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-19-2005, 11:57 AM
911gilley's Avatar
Thanks all. I finally located one for around $50.
I decided not to try the fabricated method. This line is on the pressure side of the system, and since it is directly over the intake mans, I did not want to risk fire. Besides, the original "flexible" part of the line is a unique type of tubing....it has a plastic core approx 3mm id, then this is wrapped by braided cloth, then encapsulated in a semi-hard rubberized coating. I looked on McMaster and did not see anything of this nature. I assume Porsche had some mad reasoning for engineering the part this way, just as they do for most other things. The part was cheap enough to just play it safe, buy it preman'd and bolt it on.
By the way, the part number is 930.110.494.00 for 1981 and up SC's. 1980 and older use a different part number (I think it is a complete hard line).
Ed
'95 993 Cabriolet
Old 04-20-2005, 06:34 AM
Ed,
Where did you end up buying the line? Is it already bent properly to fit alongside the other lines?
Mike
Old 04-20-2005, 10:21 AM
911gilley's Avatar
I got Al at PartsHeaven to find a new one for me since our Host does not stock this item ((800) 767-7250).
It is a stock line so I am assuming it will be formed properly to fit right in as the old one did. I'll post back when I put it in if it does not.
Ed
'95 993 Cabriolet
Old 04-20-2005, 11:35 AM
Ed,
Thanks for the info. Al also found me a new AAR for my 81 SC when I needed it a whle back.
Mike
Old 04-20-2005, 11:43 AM
Ed,
Did you get the fuel line yet? Did it fit? Also, I would be interested in where the part actually came from.
Mike
Old 05-03-2005, 06:59 AM
911gilley's Avatar
Yes Mike,
I got it as promised from Al. It was a Porsche-tagged new oem part and fit perfectly...all the proper bends, etc. What do you mean by "where the part acutally came from"? Do you mean the location in the car?
Ed
'95 993 Cabriolet
Old 05-03-2005, 09:28 AM
Ed,
I was curious about the parts house it came from. My understanding was that Al was going to find it somewhere else. I am interested in buying one also, but didn't want to bother Al if I could just buy it direct. Glad it worked well.
MIke
Old 05-03-2005, 10:06 AM
911gilley's Avatar
Mike,
It was Al at PartsHeaven, but I don't know where Al pulled the part from...I guess one of their vendors.
-Ed
Ed
'95 993 Cabriolet
Old 05-03-2005, 10:31 AM
